I have an electronic beginner question about the molex connector :
Here it is the schematic of the molex connector for dynamixel servo in circuitmaker :
How can I know where is the pin number 1 of the schematic on the real connector ?
I try to have a look on the datasheet http://www.molex.com/pdm_docs/sd/022035035_sd.pdf but found nothing about a numerotation of the pin ? Also try to find out something on circuitmaker with the link between real and schematic but didn’t success
You just have to plug it on the RPI with the header on the left, a DC power source 7v on the DC Jack, and the XL320 chain.
This board convert Motor tension to RPI tension and drive XL320 network from RPI UART. This board is all you need if you have ergo JR and RPI… We are planning to produce it soon with génération robot…
If you need it now this version pass all our tests, you can produce it by yourcelf.
An other way is to produce PCB with PCBpool or something like that, buy all needed components on farnell, and mount it and solder it by yourself (you will need some soldering advanced skills…)
An other other way is to wait a little bit the first production bash of Génération robot to split the price with many other poppy friends!
This is relative to the producer tooling, eurocircuit seems to have small performance compared to some others.
This is interesting you sould change all via size in the original design I don’t think you can pull request on CircuitMaker. We just send a production to CircuitHb and there is no problem at the moment…
Have you tested the board you ordered ? Does it works correctly ? And last question, I would like to use this board in an educational way, is there any documentation to describe how it works ?
This component is not the hardest one… look at the TPS54427DDAR, he has a really tricky pad…
We have a small problem with our ordered board, we had a reference worries with 3 resistors, we have to change them in all our boards.
We need to test them in hard condition, after that we will introduce it officially with some documentation, of course!
