The Data sheet of the humanoid poppy 1.0 robot
HELLO EVERYBODY!
I am looking for THE data sheet of the humanoid robot POPPY 1.0. We want to buy the robot for the laboratory, someone can give me the link where I can download it?
Hi !
There’s too much things to have a single datasheet for Poppy.
Have a look at Getting started with Poppy Project to get started (you will also find the list of all components, the BOM), at https://github.com/HumaRobotics/poppy-examples/tree/master/doc for some doc and at http://www.generationrobots.com/fr/402077-kit-robot-humanoide-poppy-10-avec-impressions-3d.html to buy at kit !
What do you intend to do with Poppy ?
we want to buy a complet kit of humanoid robot poppy. We must to have the complet datasheet of the robot in PDF format.
Would this fit you ? https://github.com/HumaRobotics/poppy-examples/blob/master/doc/full-datasheet.pdf
It contains a description of the Poppy project, the Poppy Humanoid bill of material, the assembly guide and the software quickstart.
I work for Generation Robots, the Poppy distributor. If you need a quotation, send me a private message.
