[Wiring] - Is there a place to find information on poppy (power) wiring?
Hi all,
I’m actually looking for information to wire the poppy head, with generation robot poppy electronic kit,
I’ve found the following post about data bus
and this is the head part list I identify at this point
with available parts (from generation robot kit)
ODROID U3 Board
eMMC 8Go - Ubuntu pre - installed
µP Fan
UBEC
USB Webcam & Cable
Audio Amp
Speakers
Jack power plug (2,5 mm ext - 0,8 mm int)
Wifi dongle
USB Hub 4 ports
and needed part but non included
Stereo jack 3,5 mm male plug (right angle suggested)
Audio stereo wire (15 cm) (note : red - right / white - left)
Speakers cable (2 x 15 cm)
Audio power amplifier power wire (15 cm)
Micro HDMI → HDMI (only for software setup)
HDMI Display (only for software setup)
USB Mouse (only for software setup)
USB Keyboard (only for software setup)
Ethernet RJ45 cable
I’m particulary looking for power wiring in order to prepare the head wiring and software install before the april assembly party.
Where the ODROID power is coming from ?
Where the Audio amp power is taken from ?
What are the needed screws faor the ODROID ? the webcam ?
Thank’s for your help !
I @Lionel,
We will do a small tutorial today about wiring.
Effectively you will need to buy some parts, I will give you refences for that!
For software setup we have a really new and beta way to install Poppy. With this really new way you only need to have your preinstalled ubuntu and a Ethernet RJ45.
Please look at this and give me some feedback :
Thx,
I’m absolutely ok and glad to check and help with the poppy installer,
but I need to power on the ODROID and would like to be in the poppy wiring situation.
I’d like to create a howto and would like to be in real realistic situation :grin:
You can find the soldering tutorial on github :
https://github.com/poppy-project/Poppy-minimal-head-design/blob/master/doc/poppy_soldering.md
The wiring tutorial will come tomorow because we have to open a Poppy to take some pictures…
@Lionel you can find the wiring tutorial here :
https://github.com/poppy-project/Poppy-minimal-head-design/blob/master/doc/poppy_wiring.md
