Dear all,
I am using V1.1 of poppy, and I started to use the ipython note book. I am using the following code:
Any idea ?
Thx!
Youâre missing the poppy-creature library. You can get it from pip or github.
Didnât you install your system from poppy_install ?
yes I did install the system from poppy_install
can you do a âpip show poppy-creatureâ ?
nothing ⌠I get nothing back ![]()
oh, but thatâs probably normal as poppy_install uses github⌠Let me have a look (even if my Poppy got kidnapped todayâŚ)
Well; let install it:
go in /dev
do you have a poppy-creature folder ?
if no: git clone https://github.com/poppy-project/poppy-creature.git
cd poppy-creature/software
python setup.py build (not sure if needed)
python setup.py install
then installation test:
python
import poppy.creatures
Edit:
poppy_install probably failed to install pypot because of the add of scipy, this is now corrected on the repository.
Try this on the shell of the odroid
sudo apt-get install libblas3gf libc6 libgcc1 libgfortran3 liblapack3gf libstdc++6 build-essential gfortran python-all-dev libatlas-base-dev
pip install poppy-humanoid -U
I followed @Theo instructions, and now the notebook program works.
I have now other issues (some python error codes about the id of the motors⌠from time to time). On this âissueâ I will come back to you in another thread, I guessâŚ
By the way, in the installation log, I could not find any error message (I searched for the word âpypotâ⌠I found a section about it, no errors⌠)
Again, thx for your help !
@ribas Feel free to pull request poppy_install to have install logs !
I have a question, you install a jupyter notebook inside the poppy and open the notebook in the terminal of poppy?
@Ziqi Jupyter Notebook is already installed on the Poppy.
Connect your Poppy to an RJ45 cable to your computer. From your computer open URL http://poppy.local in Firefox. If it does not load successfully, check that âBonjour for WIndowsâ is installed and retry.
Then click on Programming and Jupyter / Python.
olalalala, I will try this, thank you very much
