Problème de création d'un PoppyHumanoid avec Pypot pour utiliser V-Rep
I work on poppy for an academic project. For the programming aspect I decided to follow the tutorial:how you can control a simulated Poppy Humanoid using a robot simulator.
However, when I tried to execute the following script:
I received this issue:
Well,searching on the forum I found a post on a similar issue with the module ‘creatures’. So I tried the offered solution but I still have the same issue.
The offered solution was to use:
from poppy_humanoid import PoppyHumanoid
Instead of using:
Has someone already faced this issue ?
Thanks for your help!
Did you installed the poppy-creature package ?
pip install poppy-creature
Yes, when I tried to re install this package python says that this package is already install.
But it changes the issue that raise python, now I receive this issue when i execute the same script than before:
Ok then, did you installed poppy-humanoid ?
It is pip install poppy-humanoid or if you have cloned the repository and want to do development:
cd poppy-humanoid/software/
python setup.py develop
I try to uninstall and install all pypot and poppy humanoid
Here is my installation:
But I still have the same issue.
I try to follow line by line the tutorial : how you can control a simulated Poppy Humanoid using a robot simulator.
So I think that I have already install all packages asked by this tuto.
Someone else had the same isssue:
Maybe try to rename your poppy.py file by something else ?
I had already saw this post before.
I tried to rename my file and replaced:
by
As it’s explain in this post but in my case the issue is not related with the issue raised in this post.
So I really don’t understand why I still have this issue of ImportError, maybe I missed something…
Can you try: python -c "import pypot" ?
If you obtain this error:
  File "<string>", line 1, in <module>
ImportError: No module named pypot
You have probably a problem with your python environnement i.e. your pip use another python than your system.
If this line does not raise any error then I do not know… you may have to wait for @Pierre to come back (monday).
I tried and this is the result:
I guess that I have no error
Thanks for your help and I will wait monday
En fait j’ai le même problème…
Est ce que tu peux me montrer la version du code que tu as pour le fichier software/poppy/creatures/abstractcreature.py du module poppy-creature qui visiblement doit être dans ton /usr/local/bin/python2.7/dist-packages/
Voila le fichier que tu veux:
import os
import re
from pypot.robot import Robot, from_json
from pypot.server.snap import SnapRobotServer
def camelcase_to_underscore(name):
    s1 = re.sub('(.)([A-Z][a-z]+)', r'\1_\2', name)
    return re.sub('([a-z0-9])([A-Z])', r'\1_\2', s1).lower()
class AbstractPoppyCreature(Robot):
    """ Abstract Class for Any Poppy Creature. """
    def __new__(cls,
                config=None,
                simulator=None, scene=None, host='127.0.0.1', port=19997, id=0,
                use_snap=False, snap_host='0.0.0.0', snap_port=6969,
                sync=True):
        """ Poppy Creature Factory.
        Creates a Robot (real or simulated) and specifies it to make it a specific Poppy Creature.
        :param str config: path to a specific json config (if None uses the default config of the poppy creature - e.g. poppy_humanoid.json)
        :param str simulator: name of the simulator used (only vrep for the moment)
        :param str scene: specify a particular simulation scene (if None uses the default scene of the poppy creature - e.g. poppy_humanoid.ttt)
        :param str host: host of the simulator
        :param int port: port of the simulator
        :param int id: id of robot in the v-rep scene (not used yet!)
        :param bool sync: choose if automatically starts the synchronization loops
        .. warning:: You can not specify a particular config when using a simulated robot!
        if config and simulator:
            raise ValueError('Cannot set a specific config '
                             'when using a simulated version!')
        creature = camelcase_to_underscore(cls.__name__)
        base_path = os.path.dirname(__import__(creature).__file__)
        if config is None:
            config = os.path.join(os.path.join(base_path, 'configuration'),
                                  '{}.json'.format(creature))
        if simulator is not None:
            if simulator != 'vrep':
                raise ValueError('Unknown simulation mode: "{}"'.format(simulator))
            scene_path = os.path.join(base_path, 'vrep-scene')
            if scene is None:
                scene = '{}.ttt'.format(creature)
            if not os.path.exists(scene):
                if ((os.path.basename(scene) != scene) or
                        (not os.path.exists(os.path.join(scene_path, scene)))):
                    raise ValueError('Could not find the scene "{}"!'.format(scene))
                scene = os.path.join(scene_path, scene)
            # TODO: use the id so we can have multiple poppy creatures
            # inside a single vrep scene
            poppy_creature = from_vrep(config, host, port, scene)
            poppy_creature.simulated = True
        else:
            poppy_creature = from_json(config, sync)
            poppy_creature.simulated = False
        if use_snap:
            poppy_creature.snap = SnapRobotServer(poppy_creature, snap_host, snap_port)
        cls.setup(poppy_creature)
        return poppy_creature
    @classmethod
    def setup(cls, robot):
        """ Classmethod used to specify your poppy creature.
        This is where you should attach any specific primitives for instance.
        pass
Bon bah c’est pas ça. Désolé, j’ai pas de réponse pour le moment.
It should have been fixed in the version 1.5.1 of poppy creatures:
Soory but I still have the same issue even after have installed the new version of poppy creatures.
This is the executed script:
And finally this is the error message:
Can you run the following command in your terminal and post the result:
pip list | grep 'poppy\|pypot'
Then, for your script can you try instead:
#!/usr/bin/env python
Here is the result of the execution:
It seems that you are still working on a directory named poppy, with a module named poppy. This is really not a good idea as this will completely confused the python interpreter. Can you try move your blabla file somewhere else and try again?
Indeed it was just an issue of module.
I moved blabla and that is the result:
Is the V-Rep error is problematic to continue the programmation ?
However I have this:
This error shows that there was a timeout in the connection with v-rep.
Maybe the pop-up about “undo” feature taking too much time ?
