DISCLAIMER: This tutorial is only intended to show how we manage to make everything needed to control Poppy works on Windows 8. As we are not Windows developers there may be (hopefully) better way of doing so. Do not hesitate to comment and complete this doc (by clicking on the Wiki pen icon on the left of this Wiki post)!
EASY SOLUTION
install anaconda it will install python, numpy, scipy, matplotlib, pip, python, and PyQt4 for you
for the other dependencies see the manual installation below
Manually Install Python
python 2.7: we recommend to use the 32bits version as it’s harder to find precompiled windows package for the 64 bits version. We only tried python 2.7 on windows, yet version 3 or later should also work. You may have to restart your computer for python to be in the path
You can follow this tutorial or this one. Be careful when downloading the .inf file as windows tends ton convert it to a .txt file breaking the end of line.
could just be me typing in the wrong thing but whenever i type pip install poppy_humanoid it comes back with “could not find a version that satisfies the requirement of poppy_humanoid
cleaning up”
Hello, I already installed all the software and the driver USB2AX. I’'m using Windows 7. I’m following the pypot tutorial to control the motors in low level. This is the code I’m running:
import pypot.dynamixel
if not ports:
raise IOError('no port found!')
print 'ports found', ports
print 'connecting on the first available port:', ports[1]
dxl_io = pypot.dynamixel.DxlIO(ports[1])
found_ids = dxl_io.scan()
dxl_io.get_present_position((1, ))
dxl_io.set_goal_position({1: 120})
I can see the available ports and I try to connect with the port where I have the USB2AX. There is neither an error nor an answer for the scan motors instruction, or the get and setposition. Did anyone have this kind of problem?
