Poppy corrupted?
I found this morning that a library has been corrupted on my Poppy Humanoid. Last week it was my git project. It did already happen a few weeks ago.
Do someone else have the same problems or may my setup be culprit (soldering, …) ?
“Corrupted” like a corrupted file on the File-system ?
Are you using a SD card or the MMC ?
I’ve experienced that with a old Raspberry Pi. I corrupted the File System after accidentaly cutting off the power while the board was upgrading…
Yes, corrupted file on the file system. I didn’t do upgrades yesterday, but maybe I should check my power wires.
I wanted to check if others had the problem, but if it’s not the case, it’s probably my system.
Edit : I have the eMMC
