Etcher, and poppy torso img
it seems there is a problem with an image.
I use the doc
https://docs.poppy-project.org/en/
Download the image of the operating system
and
Write the operating system image to the SD card
with the file
2017-04-06-poppy-ergo-jr.img.zip
i haven’t got any problem
But with the second one
poppy-torso-xu4-2016-05-25.img.zip
I have got always the same error when i use Etcher
Tank Gilles for your help
Same problem with linux one 4GoSD
I try again with a 64Go SD and’ve got the same error message with etcher …
Ok i 'm quite sure the .zip file is defective. It’s impossible to unzip the file !
So is it possible to update the gitub with a good file !
Thank you
Indeed I had many problems to unzip that file (on Xubuntu 16.04). I finally did it (in command line) but, as Luc says, this archive is suspect #1.
@Theo @damiend @Generation_Robots_VM
It’s quite weird.
i’ve downloaded this image a few years ago and never had any problem as observed.
I am currently investigating directly with @luc_vincent, we will let you know.
@Theo, any feedback about an issue like that?
Up.
I’ve sent my image.zip to @luc_vincent but the same problem, whereas I’ve always succeed to flash eMMC cards with this one.
Could you try with Linux with a 8Go SD card ? The image is more than 4Go so that can explain why you did not succeed
I ve got the solution !
There is a problem with the .zip file on github it’s not compatible with windows extract …
First i use 7zip to unzip the downloaded file poppy-torso-xu4-2016-05-25.img.zip
Then you can use etcher to programm the SDcard or eMMC.with the unzipped file poppy-torso-xu4-2016-05-25.img
Damien I send you all the explanation in french …I suggest to update the .zip file on github with a new one made on windows !
You can download it for a while the file
"poppy-torso-xu4-2016-05-25_win.img.zip" on adress
http://dl.free.fr/iao3JWODx
This file will be delete after 30 days without download
wow thanks for this solution.
