Hello Fabrice,
I received the RAZOR IMU and played with it. It seems to be a good one (moreover, we can hack the soft).
I did some tests (not done in the videos…)
1)
- Put the sensor horizontally on the table
- turn 360deg around Z axis
- see the value of roll and pitch are small
It is true for the RAZOR
- lift and shake it in all directions violently
- return the sensor on the table
- Put the sensor haorizontally on the table
- lift and hit the sensor on the table violently (shocks)
- move the sensor sideway
- see the roll angle is small
All these tests are OK with the RAZOR
I can trust the measurement. I wish I will not have any issue later with this one…
I have to stick the sensor on Poppy now.
