For our project we are optimizing an arm of poppy in order to animate his hand. And I thought to program it with V-Rep.
So I have a question :
How can I switch from my entire simulated poppy to my real arm in V-Rep?
Best Regards
Tanguy
Best Regards
Tanguy
Very good way:
OK way:
(very) Ugly way:
broken = true option in your config file for all motors which are not in the real robot, e.g:"r_hip_y": {
"offset": 0.0,
"type": "MX-64",
"id": 23,
"angle_limit": [
-85,
105
"orientation": "indirect",
"broken": true,
Ok ! Thank you very much for answering,
So, in this case how can simulate only an arm on V-Rep ?
Is there any command as:
poppy=PoppyHumanoid(simulator=‘vrep’)
to simulate only the arm ?
You have to edit the v-rep scenes and keep only the arm. This can simply be done by deleting the parts you do not want.
Then you create the config (e.g. “poppy_arm.json”) and import it:
import json
import pypot.robot
arm = pypot.robot.from_json('poppy_arm.json')
