We have installed the odroid with the basic pypot image with the webinterface and we use the usb2ax contoller.
The motors of the poppy humanoid are connected and we did not change anything.
But in the webinterface we get this error:
Attempt 1 to start the robot...
Connection to the robot failed! No suitable port found for ids [31, 32, 33, 34, 35, 36, 37, 41, 42, 43, 44, 51, 52, 53, 54]. These ids are missing [32, 33, 34, 35, 36, 37, 41, 42, 43, 44, 51, 52, 53, 54, 31] !
Attempt 2 to start the robot...
Attempt 3 to start the robot...
Attempt 4 to start the robot...
Attempt 5 to start the robot...
Could not start up the robot...
File "/home/poppy/.pyenv/versions/2.7.11/bin/poppy-services", line 9, in
load_entry_point('poppy-creature==1.8.1', 'console_scripts', 'poppy-services')()
File "/home/poppy/.pyenv/versions/2.7.11/lib/python2.7/site-packages/poppy/creatures/services_launcher.py", line 179, in main
File "/home/poppy/.pyenv/versions/2.7.11/lib/python2.7/site-packages/poppy/creatures/services_launcher.py", line 38, in start_poppy_with_services
raise exc_inst
IOError: Connection to the robot failed! No suitable port found for ids [31, 32, 33, 34, 35, 36, 37, 41, 42, 43, 44, 51, 52, 53, 54]. These ids are missing [32, 33, 34, 35, 36, 37, 41, 42, 43, 44, 51, 52, 53, 54, 31] !
