I am running the robot on Windows platform on my PC but the odroid board in the robot has a Ubuntu Linux platform. I tried to link the humanoid with my PC using the ethernet cable via a switch and I was able to ping the IP address of the robot from the PC. only when I type http://10.118.18.89/ I get the following web interface which seems to be working
But I ignored the poppy.local link and I have approached the web interface using the IP address. If I go to python terminal, it says connection failed. And I got these errors in the log file of web interface:
No handlers could be found for logger “poppy.creatures.abstractcreature”
Attempt 1 to start the robot…
[Errno 16] could not open port /dev/ttyACM1: [Errno 16] Device or resource busy: ‘/dev/ttyACM1’
Attempt 2 to start the robot…
Attempt 3 to start the robot…
Connection to the robot failed! No suitable port found for ids [31, 32, 33, 34, 35, 36, 37, 41, 42, 43, 44, 51, 52, 53, 54]. These ids are missing [32, 33, 34, 35, 36, 37, 41, 42, 43, 44, 51, 52, 53, 54, 31] !
Attempt 4 to start the robot…
Attempt 5 to start the robot…
SnapRobotServer is now running on: http://0.0.0.0:6969
You can open Snap! interface with loaded blocks at “http://snap.berkeley.edu/snapsource/snap.html#open:http://10.104.55.51:6969/snap-blocks.xml”
HTTPRobotServer is now running on: http://0.0.0.0:8080
Robot created and running!
tract_io.py", line 357, in my_getter
return self._get_control_value(control, ids, **kwargs)
File “/home/poppy/.pyenv/versions/2.7.11/lib/python2.7/site-packages/pypot/dynamixel/io/abstract_io.py”, line 412, in _get_control_value
sp = self._send_packet(rp, error_handler=error_handler)
File “/home/poppy/.pyenv/versions/2.7.11/lib/python2.7/site-packages/pypot/dynamixel/io/abstract_io.py”, line 529, in _send_packet
sp = self.__real_send(instruction_packet, wait_for_status_packet, _force_lock)
File “/home/poppy/.pyenv/versions/2.7.11/lib/python2.7/site-packages/pypot/dynamixel/io/abstract_io.py”, line 494, in __real_send
status_packet = self.__real_read(instruction_packet, _force_lock=True)
File “/home/poppy/.pyenv/versions/2.7.11/lib/python2.7/site-packages/pypot/dynamixel/io/abstract_io.py”, line 505, in __real_read
data = self._serial.read(self._protocol.DxlPacketHeader.length)
File “/home/poppy/.pyenv/versions/2.7.11/lib/python2.7/site-packages/serial/serialposix.py”, line 495, in read
raise SerialException(‘device reports readiness to read but returned no data (device disconnected or multiple access on port?)’)
SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
Exception in thread Thread-1:
File “/home/poppy/.pyenv/versions/2.7.11/lib/python2.7/threading.py”, line 801, in __bootstrap_inner
self.run()
File “/home/poppy/.pyenv/versions/2.7.11/lib/python2.7/threading.py”, line 754, in run
self.__target(*self.__args, **self.__kwargs)
File “/home/poppy/.pyenv/versions/2.7.11/lib/python2.7/site-packages/pypot/utils/stoppablethread.py”, line 121, in _wrapped_target
self._setup()
File “/home/poppy/.pyenv/versions/2.7.11/lib/python2.7/site-packages/pypot/dynamixel/syncloop.py”, line 22, in setup
[c.start() for c in self.controllers]
File “/home/poppy/.pyenv/versions/2.7.11/lib/python2.7/site-packages/pypot/robot/controller.py”, line 25, in start
self.wait_to_start()
File “/home/poppy/.pyenv/versions/2.7.11/lib/python2.7/site-packages/pypot/utils/stoppablethread.py”, line 86, in wait_to_start
‘for details.’.format(self._thread.name))
RuntimeError: Setup failed, see Thread-2 Tracebackfor details.
Connection to the robot failed! No suitable port found for ids [31, 32, 33, 34, 35, 36, 37, 41, 42, 43, 44, 51, 52, 53, 54]. These ids are missing [31] !
Connection to the robot failed! No suitable port found for ids [31, 32, 33, 34, 35, 36, 37, 41, 42, 43, 44, 51, 52, 53, 54]. These ids are missing [32, 34, 35, 36, 37, 41, 42, 43, 44, 51, 52, 53, 54, 31] !
Setup failed, see Thread-1 Tracebackfor details.
Could not start up the robot…
File “/home/poppy/.pyenv/versions/2.7.11/bin/poppy-services”, line 9, in
load_entry_point(‘poppy-creature==1.8.1’, ‘console_scripts’, ‘poppy-services’)()
File “/home/poppy/.pyenv/versions/2.7.11/lib/python2.7/site-packages/poppy/creatures/services_launcher.py”, line 179, in main
File “/home/poppy/.pyenv/versions/2.7.11/lib/python2.7/site-packages/poppy/creatures/services_launcher.py”, line 38, in start_poppy_with_services
raise exc_inst
IOError: Connection to the robot failed! No suitable port found for ids [31, 32, 33, 34, 35, 36, 37, 41, 42, 43, 44, 51, 52, 53, 54]. These ids are missing [32, 33, 34, 35, 36, 37, 41, 42, 43, 44, 51, 52, 53, 54, 31] !
Then I decided to go to the python notebook not through the web interface of the robot but through the anaconda navigator and I wrote the following code to see what happens
Then I got all the errors that I have listed in my previous post .
So the problem is that, I am not able to operate the web interface properly and I am getting all sorts of errors.
Thanks in advance for the help.
