I just finished to assemble all the electronic & mechanical parts in the head and there is an interference between the head of the M2.5 screws to fix the camera support and the webcam board itself
It’s a bit sensitive because the screws are metallics and they touch the webcam pcb, a capacitor is gone away due to this on mine… (still working, probably power filtering) and a short circuit can easily appear…
Ok so I opened our Poppy head and indeed the bolt is touching the CMS capacitor.
Instead of offsetting the camera as your spacers do, I moved upward as much as possible (1.5mm) the M2.5 bolt but normally, the bolt head should be juste above the camera PCB.
