Here’s a small piece of python to add controls on XL-320 leds.
io_320 monkey patch
Adds accessors to rgb leds.
Ex:
>>> dxl = Dxl320IO(get_available_ports()[0],baudrate=1e6)
>>> dxl._set_LEDRGB({17:5})
from pypot.dynamixel.io import io_320
io_320._add_control('LEDRGB',**{
'address': 0x19,
'length': 1,
'dxl_to_si': lambda v,_ : int(v),
'si_to_dxl': lambda v,_ : int(v) & 0b111,
'setter_name': '_set_LEDRGB',
'getter_name': '_get_LEDRGB'
You can open a pull request for that
Done.
I’ve also written this example primitive.
class ChristmasBlink(LoopPrimitive):
_set_LEDRGB example
>>> poppy = PoppyErgoJr()
>>> poppy.attach_primitive(ChristmasBlink(poppy, 3),'blink')
>>> poppy.blink.start()
def setup(self):
self.controller_io = self.robot._controllers[0].io
self.motors = self.robot.motors
self.motors_sz = len(self.robot.motors)
self.idx = 0
def update(self):
for num, motor in zip(xrange(self.motors_sz),self.motors):
self.controller_io._set_LEDRGB({ motor.id: (self.idx + num) % 3 })
self.idx = (self.idx + 1) % self.motors_sz
Accessing to RGB LED via robot._controllers is quite ugly.
There might be a smarter way to do write it, by creating a led controller or whatever.
Pierre
4
Thanks @aristofor ! I’ve just merged it:
I add an Enum for the color so now you can do something like:
io.set_LED_color({motor.id: 'pink'})
