Hi everyone !http://poppy-project.github.io/pypot/controller.html#writing-the-configuration
Finally, I want to power the robot with Pypot like Poppy or Ergo robots.
Thank you in advance !
              Did you check this repository ?
Also can you show us picture of the actual wiring so we can check if everything is alright ?
              I checked this repository, it’s just to run the ErgoJr, not to make another configuration …
              yep but it is very similar, you just have to take the ErgoJr configuration and change it for your robot.
import json
import pypot.robot
my_robot = pypot.robot.from_json('my_new_robot.json')
              I receive a “ValueError: No JSON object could be decoded” error when i try
              can you copy/paste your json file ?
              There is a test config file with one motor.
test_robot = {
        "controllers": {
            "my_dxl_controller": {
            "sync_read": true,
            "protocol": 2,
            "attached_motors": [
            "testm",
            "port": "auto"
        "motorgroups": {
            "testm":["
                m1,
        "motors":{
            "mtest":{
                "m1": {
                "offset": -45.0,
                "type": "XL-320",
                "id": 3,
                "angle_limit": [
                -135.0,
                45.0
              There are several syntax errors in yout config file, it is why you get this error.
This one should be better:
  "controllers": {
      "sync_read": true,
      "protocol": 2,
        "group1"
      "port": "auto"
  "motorgroups": {
      "group1":[
          "m1",
  "motors":{
    "m1": {
      "offset": 0.0,
      "type": "XL-320",
      "id": 3,
      "angle_limit": [
      -150.0,
      150.0
      "orientation": "direct"
              I receive a “ValueError: No JSON object could be decoded” anyway …
              I edit the file like this:
       "controllers": {
                            "sync_read": true,
                                "protocol": 2,
                                    "group1"
                                "port": "/dev/tty.usbmodem1411"
                        "motorgroups": {
                            "group1": [
                                "m1"
                        "motors": {
                            "m1": {
                                "offset": 0,
                                "type": "XL-320",
                                "id": 3,
                                "angle_limit": [
                                    -150,
                                150
And I received a “NotEmplementedError”. Take a look at the screenshot :
              can you show us how you have connected your motor ?
              The [3] XL-320 motor is connected thru the SMPS2Dynamixel and the USB2AX via USB port
              Did you notice that the XL320 need a 7v power supply and not 12V ?
              I powered the XL-320 with 12v, I try to 7V and it works! ?
Thank you for fast responses !
              cool mystery solved !
I think the motor raises an error above 9v and this error may not be handled by pypot.
http://support.robotis.com/en/product/dynamixel/xl-series/xl-320.htm
                Pierre
                    April 10, 2015,  8:51am
                  16
              You will also have this “none error” if you use a 5V alimentation btw.
