STEP 1: We have just laser sintered the Poppy files and are trying to confirm that the size is accurate before we purchase the rest of the components. We are thrilled to be contributing to the Poppy Project community. We will be positing all of our updates as we continue to evolve Poppy here at The 3D Printer Experience in Chicago.
Please confirm this is the actual size based on the ruler next to the print. Also, please fix being able to only post one picture as we would like to have posted two. So you can actually see what the ruler says on it up close.
Is it your printer ? The result is really impressive.
The relative size of the parts looks good yet it is difficult to say if the absolute size is ok. Can you add a picture with just a leg and the ruler please ?
Here is a photo of the leg section (lower) With easier to read measurements.
We do not have a seat for Solid works yet (in process but not yet) So I used eDrawings to open the file and convert to stl… Does it change the scale of the parts when using this workflow compared to opening the files in Solidworks? I made no adjustments, just opened the parts and then exported to STL.
OK so for those downloaded parts the leg section is coming in at 189.64mm. in length as the previous image was measured. Is this sounding better? Just want to make sure before we print again.
I have been off site for the past 3 weeks and now back in the drivers seat of building Poppy. We need to locate some Robotics experts in the chicago area to assist us in building Poppy. We have all the pieces printed at this time. We have contacted local universities, but have not been successful there.
Please give us some contact names of who we can call in our area to help us construct the robot.
