I ve made a tuto for my student to install the ergoJR simulation
It seems something change …Iv got a new computer and i try to install the simulation of the robot …
Computer W10 64B Pro
Anaconda Install Anaconda3-5.1.0-Windows-x86_64.exe OK
Test Hello world on spyder OK
With the new version you have to install some modules
I use now Anaconda promp Execute as admin
Command :
pip install pyserial
I’s OK
Command
conda install -c conda-forge bottle
It’s OK
Command
pip install pypot --user -U --no-deps
Its OK
Command
pip install poppy-creature --upgrade --no-deps
It’s OK
Command
pip install poppy-ergo-jr --user -U --no-deps
Its’OK
Now I run python and test
from pypot.creatures import PoppyErgoJr DOESN’T WORK
I tried
from pypot.creatures import * witch is OK
But then
robot = PoppyErgoJr(simulator=‘poppy-simu’, use_http=True) does’nt work
what can i do ?
Thanks for your help !
Sorry
