Is there anybody who use the Web simulator ?
I try to run it with
from pypot.creatures import PoppyErgoJr
robot = PoppyErgoJr(simulator='poppy-simu')
There is no answer in the notbook and the simualtor doesn’t move !
Please Help me !
Please Help me !
Hi Luc,
You’re right, since pypot>3 there is no more print output when you instantiate the robot in Python.
Moreover, if you don’t have a traceback everything should be working well.
First open a python terminal/ide/Jupyter notebook and exectute this code:
# You can make it move
robot.dance.start()
Note that if you use pypot 3.1, 3.2 or 3.3 you have to add use_http=True, due to this bug/breaking change
robot = PoppyErgoJr(simulator='poppy-simu', use_http=True)
And if you want program the robot with Snap! and no python exectute this code:
robot = PoppyErgoJr(simulator='poppy-simu', use_http=True, use_snap=True)
Now, you can open the poppy-simu webpage http://simu.poppy-project.org/poppy-ergo-jr/
If you open the webpage from the same computer than where the python is started, you can let 127.0.0.1 in the “hôte” input, otherwise you have to put the local IP (of the Raspberry Pi if you use the Jupyter instance of the Ergo Jr robot)
And check “synchroniser” checkbox.
Hello Theo,
All is ok now ! with Simulator/ Notebook
My aim is now to use snap /simulator
The web adress http://simu.poppy-project.org/ drive me on
http://simu.poppy-project.org/snap/
This snap have no blocks to drive the robot.
Where is the best site to find them ?
How can I run the snap/simulator ?
Hey everybody,
Is there anybody who use the snap/simulator and can help me to run it ?
Thanks for your help
you can lunch in python
Hi @Franc_k,
I think you have forgetten this argument :
use_http=True
try this
and tell me
Hi @tibo
Thank you for your answer,
unfortunatly it didn’t work. I get exactly the same error :
arf
On my side, it works! I will investigate!!!
What is your framework (python 2 or 3 ; with without a real robot, etc)
Anaconda 3 64 bits (windows) Notebook -> Python 3 without any real robot (yet
Whether i try :
PoppyErgoJr(simulator='poppy-simu', use_snap=True)
PoppyErgoJr(simulator='vrep', use_http=True, use_snap=True)
PoppyErgoJr(simulator='vrep', use_snap=True)
I get the same error.
But when I don’t try to use snap, it works in both poppy-simu and vrep modes.
Try to remove all xml file in
anaconda3/site-packages/pypot/server/snap_projects/
and add this xml
poppy-demo-project.xml (83.6 KB)
pypot-snap-blocks.xml (76.1 KB)
Ok I try,
I notice that in this folder i do have those tw files and i also have the ones in french. Should i delete them too ?
Deleted everything then copying the files you gave me but still the same error :’(
ok …
open anaconda terminal prompt and type:
conda env export -n root --file root_export.txt
and send us this file. it will allow us to better understand your problem …
thank you
hello all
same bug are solved in ![]()
