hello,
Thanks very much
First:
I tried to connect directly (XL-320 and MX-28) using a single connection, but there are two constraints:
- Different voltage (MX28: 12V ; XL 320: 7.4V)
- Different communication protocol (Pypot can’t change between the two protocols for the moment).
To avoid using two different source of power, i made a electronic card , where you can centralize the control.
Second:
I didnt used optimisation because I calculated the inverse Kinematics using trigonometric methods, fixing in one position the motor that was causing redundancy.
Finally, this arm is totally modifiable , in the documentation, you can find all the information necessary for tunning your own design.
Good Luck.
