I am used to work on Poppy using Spyder in the Python(x,y) distribution on Windows.
But I now work on the ODROID U3 with Ubuntu. To do so, I connect to the ODROID via SSH protocol.
It is very easy to do so on a Linux system using the “ssh -Y”(-Y for X server forwarding for GUI) command line.
But if you use Windows like me, it is more difficult. I have found a configuration which is very easy to use, I share it here (if you have better I will enjoy )
I use the MobaXterm application.
Once installed, open the application
Click on the first button on the toolbar: “Session”
A windows open, click on the first “SSH” tab
In “Remote host” type the IP adress of the ODROID system
In “Specify username” type Poppy (or odroid if it is the first time you use your ODROID)
In “Port” let it be to 22
The only tab to configure is the first one “Advanced SSH settings”
In this tab activate the “Follow SSH path (experimental)” which is very useful
Click OK button
A terminal will open, type your login and password (you can save the password)
On the left side of the terminal you have a sftp connection to your ODROID to open the files you want with the application you want on Windows
And finally, every time you launch a GUI using Qt or Tkinter, the display will be redirected to windows !!
You can use interactive widgets to do that. They are not so well documented (why?) but quite powerful. Yet, I agree with you this will not be “real time”.
