Really good design @Alexandre, I only have 2 comments.
I’m agree with @aurelien, I would like to see the double-rotation placed in the other direction, with the sagittal DoF at the back and the lateral DoF on the front.
Both limit the rotation amplitude and are not useful for the robustness of the part.
Bonus , you could reduce the gap between the foot and the motor:
There is enough room for the motor to move and so you could reduce the torque applied by the feet on the motor by reducing the lever arm.
Taking in account these comments should produce a foot looking like this:
Also after these comments, you could add an extra feature
This foot design is made to explore the balance of the humanoid robot. You just added a DoF and we (@Steve) will now be able to study how important this rotation is and what range of motion and torque are needed. Another interesting point is the position of the ankle, in particular along the length of the foot:
This could be easily done by allowing the double_rotation to be attached to the foot on several location (3 - 4 or +).
If you really need more gap, maybe you can cut the U part in 2 part to let more space.
But if Humanely, you can’t make a 90° angle with your fit too … maybe 70° max too. So it’s pretty human and sounds good
To integrate force sensors under such foot, maybe we should simply use the work done on DarwinOP ? In particular, they have an already designed and functional electronic board …
It seems to be a good device, but 400€… Each resistive sensor is 7.5€. 80€ of sensors ok but 300€ of electronic measuring resistance, I dont understand.
