Hello everybody,
I have been searching and didn´t find an answer yet. I hope you can realy healp me.
If I try to run the code
"from poppy.creatures import PoppyHumanoid
poppy = PoppyHumanoid()"
It just says :
"WindowsError Traceback (most recent call last)
<ipython-input-4-8559991d5db6> in <module>()
1 from poppy.creatures import PoppyHumanoid
----> 2 poppy = PoppyHumanoid()
C:\Users\Kevin\Anaconda2\lib\site-packages\poppy\creatures\abstractcreature.pyc in __new__(cls, base_path, config, simulator, scene, host, port, id, use_snap, snap_host, snap_port, snap_quiet, use_http, http_host, http_port, http_quiet, use_remote, remote_host, remote_port, sync)
98 else:
99 try:
--> 100 poppy_creature = from_json(config, sync)
101 except IndexError as e:
102 raise IOError('Connection to the robot failed! {}'.format(e.message))
C:\Users\Kevin\Anaconda2\lib\site-packages\pypot\robot\config.pyc in from_json(json_file, sync, strict, use_dummy_io)
242 config = json.load(f)
243
--> 244 return from_config(config, sync=sync, strict=strict, use_dummy_io=use_dummy_io)
245
246
C:\Users\Kevin\Anaconda2\lib\site-packages\pypot\robot\config.pyc in from_config(config, strict, sync, use_dummy_io)
58 attached_ids = [m.id for m in attached_motors]
59 if not use_dummy_io:
---> 60 dxl_io = dxl_io_from_confignode(config, c_params, attached_ids, strict)
61
62 check_motor_limits(config, dxl_io, motor_names)
C:\Users\Kevin\Anaconda2\lib\site-packages\pypot\robot\config.pyc in dxl_io_from_confignode(config, c_params, ids, strict)
137
138 if port == 'auto':
--> 139 port = pypot.dynamixel.find_port(ids, strict)
140 logger.info('Found port {} for ids {}'.format(port, ids))
141
C:\Users\Kevin\Anaconda2\lib\site-packages\pypot\dynamixel\__init__.pyc in find_port(ids, strict)
81 """
82 ids_founds = []
---> 83 for port in get_available_ports():
84 for DxlIOCls in (DxlIO, Dxl320IO):
85 try:
C:\Users\Kevin\Anaconda2\lib\site-packages\pypot\dynamixel\__init__.pyc in get_available_ports(only_free)
47
48 def get_available_ports(only_free=False):
---> 49 ports = _get_available_ports()
50
51 if only_free:
C:\Users\Kevin\Anaconda2\lib\site-packages\pypot\dynamixel\__init__.pyc in _get_available_ports()
34 ports = []
35 path = 'HARDWARE\\DEVICEMAP\\SERIALCOMM'
---> 36 key = _winreg.OpenKey(_winreg.HKEY_LOCAL_MACHINE, path)
37
38 for i in itertools.count():
WindowsError: [Error 2] The System can´t find the data"
If I try to run the simulation with the “v-rep” simulation everything works great.
