Bonjour, je souhaite programmer mon poppy ergo jr en python. En me referant au differents docs j’ai pu faire un programme de base de sort a qu’il se déplace simplement mais je n’arrive pas a le faire marcher. voici mon programme
poppy = PoppyErgoJr(camera= ‘dummy’)
poppy.m1.stiff = True
poppy.m2.stiff = True
poppy.m3.stiff = True
poppy.m4.stiff = True
poppy.m5.stiff = True
poppy.m6.stiff = True
poppy.m1.goal_position = 20
poppy.m1.moving_speed = 50
poppy.m1.led = ‘green’
mais un message d’erreur s’affiche je ne sais pas quoi faire, merci pour votre aide
message d’erreur
DxlError Traceback (most recent call last)
in ()
1 from poppy.creatures import PoppyErgoJr
----> 2 poppy = PoppyErgoJr(camera = ‘dummy’)
3 poppy.m1.stiff = True
4 poppy.m2.stiff = True
5 poppy.m3.stiff = True
/home/poppy/miniconda/lib/python2.7/site-packages/poppy/creatures/abstractcreature.pyc in new(cls, base_path, config, simulator, scene, host, port, id, use_snap, snap_host, snap_port, snap_quiet, use_http, http_host, http_port, http_quiet, use_remote, remote_host, remote_port, start_background_services, sync, **extra)
117 else:
118 try:
→ 119 poppy_creature = from_json(config, sync, **extra)
120 except IndexError as e:
121 raise IOError(‘Connection to the robot failed! {}’.format(e.message))
/home/poppy/miniconda/lib/python2.7/site-packages/pypot/robot/config.pyc in from_json(json_file, sync, strict, use_dummy_io, **extra)
283 config = json.load(f, object_pairs_hook=OrderedDict)
284
→ 285 return from_config(config, sync=sync, strict=strict, use_dummy_io=use_dummy_io, **extra)
286
287
/home/poppy/miniconda/lib/python2.7/site-packages/pypot/robot/config.pyc in from_config(config, strict, sync, use_dummy_io, **extra)
60 attached_ids = [m.id for m in attached_motors]
61 if not use_dummy_io:
—> 62 dxl_io = dxl_io_from_confignode(config, c_params, attached_ids, strict)
63
64 check_motor_eprom_configuration(config, dxl_io, motor_names)
/home/poppy/miniconda/lib/python2.7/site-packages/pypot/robot/config.pyc in dxl_io_from_confignode(config, c_params, ids, strict)
179 dxl_io = DxlIOCls(port=port,
180 use_sync_read=sync_read,
→ 181 error_handler_cls=handler)
182
183 try:
/home/poppy/miniconda/lib/python2.7/site-packages/pypot/dynamixel/io/abstract_io.pyc in init(self, port, baudrate, timeout, use_sync_read, error_handler_cls, convert)
73 self._serial_lock = threading.Lock()
74
—> 75 self.open(port, baudrate, timeout)
76
77 def enter(self):
/home/poppy/miniconda/lib/python2.7/site-packages/pypot/dynamixel/io/abstract_io.pyc in open(self, port, baudrate, timeout)
96
97 “”"
—> 98 self._open(port, baudrate, timeout)
99 logger.info(“Opening port ‘%s’”, self.port,
100 extra={‘port’: port,
/home/poppy/miniconda/lib/python2.7/site-packages/pypot/dynamixel/io/abstract_io.pyc in _open(self, port, baudrate, timeout, max_recursion)
118
119 if port in self.__used_ports:
→ 120 raise DxlError(‘Another instance of pypot use the port {}. You should restart your Python kernel to pass through this issue.’.format(port))
121
122 # Dirty walkaround to fix a strange bug.
DxlError: Another instance of pypot use the port /dev/ttyAMA0. You should restart your Python kernel to pass through this issue.
