hello,
i try since some day to find a way to convert poppy 3D file to a usable openscad file.
i try to convert .stl file to .scad but just have polyhedron objects and it’s no realy the good way for work under the 3D object.
regard,
major_ghz
hello,
regard,
major_ghz
Hi @major_ghz,
You will need to convert from Solidworks source files.
Maybe you can convert from STEP files ?
hi,
i try to import some files in openscad but i havn’t arrive to have some used files under openscad.
may be it’s better to ask on openscad community.
regard,
major_ghz.
witch license of Solidworks there are for work with Solidworks without too expensive for work on puppy ?
