Hello & Bonjour,
Je comprend francais, pas de problèmes avec résponses en francais, merci! Mais je préfère éxpliquer mon problème en anglais:
I hope that you can help me. We received Ergo Jr today and building it was no problem. It’s connected via cable and I can easily access the dashboard and start snap. But I cannot setup a proper connection to the robot and get “You may have connection troubles” in snap, even if I use the right IP etc.
Looking in the logs on the dashboard it says:
Attempt 1 to start the robot…
Could not initalize robot!
Attempt 2 to start the robot…
Attempt 3 to start the robot…
Attempt 4 to start the robot…
Attempt 5 to start the robot…
Could not start up the robot…
File “/home/poppy/miniconda/bin/poppy-services”, line 6, in
sys.exit(main())
File “/home/poppy/miniconda/lib/python2.7/site-packages/pypot/creatures/services_launcher.py”, line 188, in main
File “/home/poppy/miniconda/lib/python2.7/site-packages/pypot/creatures/services_launcher.py”, line 37, in start_poppy_with_services
raise exc_inst
OSError: Could not initalize robot!
What am I missing? Any additional installation needed?
Thanks a lot for any hints.
Kind regards,
Natalia
