Due to power fluctuation, one of the usb2ax stopped working (led’s not glowing) because of which upper part is not detecting.
So, is there any way of repairing usb2ax ?
Can i connect poppy robot using only one usb2ax?
If yes, kindly guide me through the steps.
Thank You
It seems to be burnt, it is pretty hard to repair an USB2AX if you are not an expert in micro electronics.
You can use one USB2AX but many errors might appear because it makes a lot of motors. I’ve tested once but there were some bugs. The best solution is to use 2 USB2AX as it has been designed.
If you do not have another one, you can find one here.
Okay @damiend, I’ll see to it.
