I’m trying to run Poppy project on my CentOS 7.0, following the README on github site. It did run when i typed poppy-server on the command line, and i could get response when i request with curl --include --request GET --header "Content-Type: application/json" -H 'X-Auth-Token:000' -H 'X-Project-ID:000' http://127.0.0.1:8888/v1.0/health.
Duplicated file poppy.conf and logging.conf to the .poppy folder, which is in the same hierarchy with poppy projcet folder.
Then the problems came: the configuration in poppy.conf doesn’t work at all! Even when i changed the name of poppy.conf to poppy.conf.backup, poppy-server can run as well. So i tried to find the log file to see what’s wrong. Unfortunately, poppy.log file could not be found in the system, nor server.log name file configured in poppy.conf.
I’ve googled a lot and tried all i can do to solve this problem. Only found that, using poppy-server --debug -v command can print out the debug info on the terminal, and the default configuration of storage and provider are in the boot file poppy/poppy/bootstrap.py.
But I still have no idea on which config file poppy use and how to log poppy info.
Thanks,
Sailaja
Puppet Developer
