This topic list some contactless sensing technology
Magnet based
Hall effect sensors
Sense the intensity and polarity of a magnetic field:
Magnetic absolute rotary encoder
Same principle sensing a magnetic field:
- http://ams.com/eng/Products/Magnetic-Position-Sensors/Angle-Position-On-Axis/AS5048A
- http://www.mouser.co.uk/new/ams/ams-as5048-adapterboard/
- http://www.mouser.co.uk/ProductDetail/ams/AS5048A-EK-AB-STM10/?qs=sGAEpiMZZMvImxLHw368xhrpVBsRhYuf
- http://forum.arduino.cc/index.php?topic=155238.0
- https://github.com/ZoetropeLabs/AS5048A-Arduino
Require Diametrically magnetised magnets: http://www.first4magnets.com/neodymium-magnets-t137#c34:t177
Inductance-to-digital converter
A Revolution in Sensing
Inductive sensing is a new, contactless, magnet-free technology that
revolutionizes sensing by delivering better performance, better reliability, and
greater flexibility than existing solutions, at a lower system cost. The LDC1000 is
the world’s first inductance-to-digital converter that enables inductive sensing.
Better Performance and Reliability
The LDC1000 provides 16-bit resonance impedance and 24-bit inductance
values, enabling sub-micron resolution in position-sensing applications. Inductive
sensing is also immune to non-conductive interferences such as dirt and dust
and it supports remote sensor placement, making it well-suited for extreme and
harsh environments.
Lower System Cost
The sensor is virtually free because the sensor can be a wound wire, a coil on a
PCB, a coil printed with conductive ink on a flexible substrate, or even a simple
spring. You also avoid the high costs of magnets, especially those requiring
rare-earth materials.
Component: http://www.ti.com/product/LDC1000
Features: http://www.ti.com/lit/ml/slyb212/slyb212.pdf
Passive NFC
NFC can power small devices and thus read from many type of sensors provided low power consumption.
The SIC4310 NFC Enabler‘s UART interface can directly drive a piezo speaker to play melodies while its GPIOs (general purpose input/output pins) are able to turn LED lights on and off using only harvested power from an NFC device.
Article: Passive NFC chip can power lights and sounds • NFCW
Components: http://www.sic.co.th/product.php?product=138
