These motors are not working anymore. I tried to perform a recovery firmware or an update firmware, but there is some problem with the IC of each motor. The motors are recognized individually, and it is possible use it. However, when are connected several motors, the communication fails. So, something is wrong with the motors that can not be recovered. You can do the self check http://en.robotis.com/model/selfcheck.php and request technical support if necessary.
juanjqo
30
Related topics
| Topic | Replies | Views | Activity | |
| [Assembly instructions] Take care of the Dynamixel motors configuration and assembly! | 31 | 16365 | April 20, 2015 | |
| Another instance using the serial port | 23 | 3579 | January 27, 2017 | |
| Problème détection moteurs Poppy | 3 | 924 | February 26, 2018 | |
| Pypot scan can't find motors but herborist does find motors | 3 | 1742 | December 1, 2015 | |
| Problem with the first start | 16 | 3646 | November 6, 2014 |
