Dear all,
Here is a trick that @Steve gave me to change the sounds of poppy when it starts, when the wifi is on, when the programs are loaded, etc.
- To change the sounds when Poppy starts
A script called startup_script.sh is executed when you power on the robot.
sudo vi /etc/Poppy/startup_script.sh
In this file, you will find all the different command to launch YOUR own sounds. Comment/uncomment the specific lines.
- To change the sounds once poppy has started:
All the sounds can be retreive under the folder Sounds/poppy/_/…/voc/
There are 100 sound files that are randomly played by the script play_rand_babbling.py
sudo vi /home/.../.../dev/poppy-software/demo/webdemo/play_rand_babbling.py
In this file, you will find all the different command to launch YOUR own sounds. Comment/uncomment the specific lines, it's very easy!
