Starting API with camera… Attempt 1 to start the robot…WARNING:root:Another instance of pypot is using the port /dev/ttyACM1. This might be an issue in Jupyter Notebook, in that case restart the kernel.WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.creatures.abstractcreature:Init fail: No suitable port found for ids [11, 12, 13, 14, 15, 21, 22, 23, 24, 25]. These ids are missing [11, 12, 13, 14, 15, 21, 22, 23, 24, 25] !WARNING:root:Another instance of pypot is using the port /dev/ttyACM1. This might be an issue in Jupyter Notebook, in that case restart the kernel.WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.creatures.abstractcreature:Init fail: No suitable port found for ids [11, 12, 13, 14, 15, 21, 22, 23, 24, 25]. These ids are missing [11, 12, 13, 14, 15, 21, 22, 23, 24, 25] !WARNING:root:Another instance of pypot is using the port /dev/ttyACM1. This might be an issue in Jupyter Notebook, in that case restart the kernel.WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.creatures.abstractcreature:Init fail: No suitable port found for ids [11, 12, 13, 14, 15, 21, 22, 23, 24, 25]. These ids are missing [11, 12, 13, 14, 15, 21, 22, 23, 24, 25] !WARNING:root:Another instance of pypot is using the port /dev/ttyACM1. This might be an issue in Jupyter Notebook, in that case restart the kernel.WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.creatures.abstractcreature:Init fail: No suitable port found for ids [11, 12, 13, 14, 15, 21, 22, 23, 24, 25]. These ids are missing [11, 12, 13, 14, 15, 21, 22, 23, 24, 25] !WARNING:root:Another instance of pypot is using the port /dev/ttyACM1. This might be an issue in Jupyter Notebook, in that case restart the kernel.WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.creatures.abstractcreature:Init fail: No suitable port found for ids [11, 12, 13, 14, 15, 21, 22, 23, 24, 25]. These ids are missing [11, 12, 13, 14, 15, 21, 22, 23, 24, 25] !WARNING:root:Another instance of pypot is using the port /dev/ttyACM1. This might be an issue in Jupyter Notebook, in that case restart the kernel.WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.creatures.abstractcreature:Init fail: No suitable port found for ids [11, 12, 13, 14, 15, 21, 22, 23, 24, 25]. These ids are missing [11, 12, 13, 14, 15, 21, 22, 23, 24, 25] !WARNING:root:Another instance of pypot is using the port /dev/ttyACM1. This might be an issue in Jupyter Notebook, in that case restart the kernel.WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.creatures.abstractcreature:Init fail: No suitable port found for ids [11, 12, 13, 14, 15, 21, 22, 23, 24, 25]. These ids are missing [11, 12, 13, 14, 15, 21, 22, 23, 24, 25] !WARNING:root:Another instance of pypot is using the port /dev/ttyACM1. This might be an issue in Jupyter Notebook, in that case restart the kernel.WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.creatures.abstractcreature:Init fail: No suitable port found for ids [11, 12, 13, 14, 15, 21, 22, 23, 24, 25]. These ids are missing [11, 12, 13, 14, 15, 21, 22, 23, 24, 25] !WARNING:root:Another instance of pypot is using the port /dev/ttyACM1. This might be an issue in Jupyter Notebook, in that case restart the kernel.WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyACM0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.dynamixel:DxlError on port /dev/ttyAMA0WARNING:pypot.creatures.abstractcreature:Init fail: No suitable port found for ids [11, 12, 13, 14, 15, 21, 22, 23, 24, 25]. These ids are missing [11, 12, 13, 14, 15, 21, 22, 23, 24, 25] !WARNING:root:Another instance of pypot is using the port /dev/ttyACM1. This might be an issue in Jupyter Notebook, in that case restart the kernel.
