I work on new primitives for the Poppy ergo JR and need to use all the angular range (-180°;180°) for the motor number 4. When i simulated this primitive all work fine, but when I try to execute on the real poppy ergo jr the motor number 4 is stay at 90 degrees.
I try to modify the config.py :
But I think this config.py is erase by another configuration file which is the poppy_ergo_jr.json. So a try to modify the json file :
But after reboot the courses are increase at -150;150 degrees:
I think there is another configuration file which overwrite my new configuration.
