Hi guys, I screw some bolts in a servomotor but unfortunately I printed the wrong head so I had to dissamble the head but I used Loctite 271 in the screws. How can I loose the bolts from the screws I joined with Loctite 271?
Thanks
Thanks
Hi @Jaimenctech,
it’s really difficult (maybe impossible), especially in this context … here is a method …
Thank you so much Tibo, I´ve been trying with different alternatives and I finally found 3 in 1 multiuse oil is a good solution for my problem.
Greetings
I use a soldering iron and it’s possible to unscrew some nuts with this technic…
I tried with a soldering iron, I achieve loose them a little. Thanks vincent
