We may not need navigation for walking right now but, since the head, has cameras, this path finding can also be modified to work with Facial Recognition, and center the camera on a person’s face. We don’t have a way to post code snippets properly formatted. I’m sure this editor can do, the Web Administrator has to change the toolbar to include the Source Code Button…
# Author: Christian Careaga (christian.careaga7@gmail.com)
# A* Pathfinding in Python (2.7)
# Please give credit if used
import numpy
from heapq import *
def heuristic(a, b):
return (b[0] - a[0]) ** 2 + (b[1] - a[1]) ** 2
def astar(array, start, goal):
neighbors = [(0,1),(0,-1),(1,0),(-1,0),(1,1),(1,-1),(-1,1),(-1,-1)]
close_set = set()
came_from = {}
gscore = {start:0}
fscore = {start:heuristic(start, goal)}
oheap = []
heappush(oheap, (fscore[start], start))
while oheap:
current = heappop(oheap)[1]
if current == goal:
data = []
while current in came_from:
data.append(current)
current = came_from[current]
return data
close_set.add(current)
for i, j in neighbors:
neighbor = current[0] + i, current[1] + j
tentative_g_score = gscore[current] + heuristic(current, neighbor)
if 0 <= neighbor[0] < array.shape[0]:
if 0 <= neighbor[1] < array.shape[1]:
if array[neighbor[0]][neighbor[1]] == 1:
continue
else:
# array bound y walls
continue
else:
# array bound x walls
continue
if neighbor in close_set and tentative_g_score >= gscore.get(neighbor, 0):
continue
if tentative_g_score < gscore.get(neighbor, 0) or neighbor not in [i[1]for i in oheap]:
came_from[neighbor] = current
gscore[neighbor] = tentative_g_score
fscore[neighbor] = tentative_g_score + heuristic(neighbor, goal)
heappush(oheap, (fscore[neighbor], neighbor))
return False
'''Here is an example of using my algo with a numpy array,
astar(array, start, destination)
astar function returns a list of points (shortest path)'''
nmap = numpy.array([
[0,0,0,0,0,0,0,0,0,0,0,0,0,0],
[1,1,1,1,1,1,1,1,1,1,1,1,0,1],
[1,0,1,1,1,1,1,1,1,1,1,1,1,1],
[0,0,0,0,0,0,0,0,0,0,0,0,0,0]])
print astar(nmap, (0,0), (10,13))
All this code does, is plot a path. If Poppy, has to overcome some obstacles as you lead along, it can no look down, and with a modified version of this code, potentially avoid kicking it could step over. It would no longer be this example. I’m 100% certain it’s a good example but, can be used many ways.
