I always get the error on the screenshot when the raspberry is connected and all the wire are connected, I just begin, can someone try to help me?
Have you configured your motors one-by-one as described in the assembly guide section 3.2.bis?
Yes I did but I found a patch for this issue :
when i start the raspberry, I need to make sure the camera led is off when I launch a notebook.
Then it works fine.
Thanks for your answer
