Je n’arrive plus a me connecter avec mes servomoteurs AX-12 et XL320
Voici le code
Message d’erreur
File “/usr/local/lib/python3.4/dist-packages/pypot/dynamixel/io/abstract_io.py”, line 511, in __real_read
header = self._protocol.DxlPacketHeader.from_string(data)
File “/usr/local/lib/python3.4/dist-packages/pypot/dynamixel/protocol/v1.py”, line 40, in from_string
raise ValueError(‘try to parse corrupted data ({})’.format(header))
ValueError: try to parse corrupted data (bytearray(b’\x00\x00\xfb\xfd’))
During handling of the above exception, another exception occurred:
File “/home/pi/Desktop/Test.py”, line 8, in
ax12_motors = (dxl_AX12_io.scan(range(60)))
File “/usr/local/lib/python3.4/dist-packages/pypot/dynamixel/io/abstract_io.py”, line 221, in scan
return [id for id in ids if self.ping(id)]
File “/usr/local/lib/python3.4/dist-packages/pypot/dynamixel/io/abstract_io.py”, line 214, in ping
self._send_packet(pp, error_handler=None)
File “/usr/local/lib/python3.4/dist-packages/pypot/dynamixel/io/abstract_io.py”, line 527, in _send_packet
return self.__real_send(instruction_packet, wait_for_status_packet, _force_lock)
File “/usr/local/lib/python3.4/dist-packages/pypot/dynamixel/io/abstract_io.py”, line 495, in __real_send
status_packet = self.__real_read(instruction_packet, _force_lock=True)
File “/usr/local/lib/python3.4/dist-packages/pypot/dynamixel/io/abstract_io.py”, line 517, in __real_read
raise DxlCommunicationError(self, msg, instruction_packet)
pypot.dynamixel.io.abstract_io.DxlCommunicationError: could not parse received data bytearray(b’\x00\x00\xfb\xfd’) after sending DxlPingPacket(id=0)
Quelqu’un à t’il une solution à ce problème ?
Merci
PS : J’ai fait un test de voltage sur les pins VCC et Data du PIXL et j’ai 0v sur la sortie Data.
