Yep we just have to finish the new mechanics of Poppy so we can fork it for a smaller one compatible with AX-18/12.
If we fork now, we will have to redo all the work a second time to update it. With CAD design, there is not yet versioning and merge tools as efficient as the ones we have for software development.
I will release the new structure ASAP so external contributors can help to create a cheaper version.
@Matthieu About the replacement of the two MX-64 motors⦠Is it necessary -maybe- for the control algorithm to be these two motors that āstrongā? If their replacement would have stall torque of around 40Kg-cm (instead of 60Kg-cm) would this affect the control that much?
The RC servo are indeed rarely exceeding 30kg/cm, the strongest I found is here.
During my search I found that Turnigy did a rought copy of the dynamixel motors (see: 1, 2, and 3). We know nothing about these servos yet: what is the communication protocol? is the mounting frame the same as the dynamixel? And they also look pretty weak, but for sure they are cheaper.
Finally just for fun, if you want to go heavy duty: 92kg/cm and 380kg/cm!
If you just want to have a standing or sitting Poppy, you do not need to have high torque. You can freely ajust the design to your needs.
They look to have the same frame so it should be compatible with the current Poppyās frames. For the control, it would require to write another pypot IO controller but with pypot 2 it will be quite straightforward
Personnaly, I would be interested if someone tries.
@jgrizou For these motors keep in mind these three factors:
Much less stall torque than MX-28
Different power supply (7.4V instead of 12V)
MX-28 resolution is 0.088 deg. TGY-S518 probably (on that price most likely ādefinitelyā) donāt use magnetic encoders which means much worse resolution.
@Thot
I do agree with your point. We can not simply compare MX with AX.
But if you look at Kondo it uses a 14kg.cm servo (even less than AX 18 18kg.cm) but still can produce good walking gaits. A tons of that listed in youtube
So I was wondering can we use AX 18 to have a smaller poppy? I was actually trying make it in budget
NicoX
Yes I know this robot. Here is an hypnotic video which shows it is possible with a condensated humanoĆÆd robot. It is then possible with a greater robot but smaller than Poppy. This is what I want to do too.
Hi @Thot
That is my inspiration too. Let me get into a bit deeperā¦
I have a BIOLOID GP and seeing Kondo walking ( the vid you referred ) I thought if Kondo servos can then we also can with AX 18. May be the skeleton of joints we need to consider most. As in GP and in Kondo I can see there is a difference in servo placement in (mainly leg section). Then I saw Poppy and the its skeleton design is interesting, more humanly. So can we not design a smaller poppy that can do all the gaits that the full grown poppy can do and keep it in budget?
See AX 18 has lot of issue making gaits ⦠(problem comes basically from Knee/Ankle/ Heap-y servos). Again CPU bat will put more load on top so the bot will become more heavyā¦more problems to come to AX 18. May be a bit expensive RX can helpā¦
NicoX
http://www.thingiverse.com/thing:476030/#files is a link to a thingiverse design creating a dynamixel case for standard servos. Iām not as interested in the complete control of the poppy robot as of yet but am very appreciative of the design. My goal is to learn about programming and potion control of the robot and teach my kids who are 2 and 4 how things work. I stumbled accross the design on thingiverse from wanting to just print components that will mock up to make a statue of the poppy until i can afford the properish motors. Now however if this works my cheap hobby servos will make a hopefully funtional robot to play with and teach my kids about.
where there is a will there is a way hope this helps anyone else in my spot to bring this great project to more people who are setback by the costs associated with building one.
