how can I restart the poppy, when the motor are overloaded (I get an error):
File "poppy-on-tracks.py", line 14, in <module>
poppy = from_json(config_path)
File "/home/odroid/dev/pypot/pypot/robot/config.py", line 191, in from_json
return from_config(config)
File "/home/odroid/dev/pypot/pypot/robot/config.py", line 143, in from_config
old_limits = dxl_io.get_angle_limit((m.id, ))[0]
File "/home/odroid/dev/pypot/pypot/dynamixel/io.py", line 392, in my_getter
return self._get_control_value(control, ids, **kwargs)
File "/home/odroid/dev/pypot/pypot/dynamixel/io.py", line 430, in _get_control_value
sp = self._send_packet(rp, error_handler=error_handler)
File "/home/odroid/dev/pypot/pypot/dynamixel/io.py", line 547, in _send_packet
f(error_handler)
File "/home/odroid/dev/pypot/pypot/dynamixel/error.py", line 35, in handle_overheating_error
raise NotImplementedError
question:
- Shall i unplug the robot (power off) or can I send an python instruction to reset the motors?
Thanks.
