I just saw that a new kind of batteries appeared : the LiPo Graphene batteries. It seems the internal resistance is much lower. The consequence is that the power delivered is much greater, the temperature under high load is lower and the number of cycle before failure is also higher. It also seems that the risk of explosion is removed. Surprizingly, the cost is also lower.
Someone has tested this kind of batteries ? Is that true ?
