ma question est toute simple, mais la réponse peut être moins…est-il possible d’utiliser Snap! pour lancer des fichiers audio sur un Poppy Humanoid?
Serait-ce envisageable?
My question is simple, but the answer may be less … is it possible to use Snap! to launch audio files on a Poppy Humanoid?
Could it be?
Bonjour Tchoun.mb
Malheureusement personne n’a pas répondu à ta question. Moi aussi je suis curieux de le savoir.
We discussed about it yesterday…
Snap! is run on your computer so if you play a sound directly with snap!, you computer will make the sound. But play a sound on your Poppy robot still possible, you have to create a primitive to play a sound on the robot and call it through Snap! using REST api.
The only Text-To-Speech decent solution on Linux is called “pico2wave” and it’s far away from the Mac OSX “say” command line… I’m very sad to don’t know any good solution to create a speaking Linux robot.
