Is there a documentation about what is the good way to add a sensor in pypot ?
I guess you need to add it in the configuration file :
“sensors”: {
“camera”: {
“type”: “OpenCVCamera”,
“index”: -1,
“fps”: 20.0,
“resolution”: [640, 480]
And create the class for your sensor, in the sensor folder :
class my_sensor(Sensor):
registers = Sensor.registers + [‘frame’, ‘resolution’, ‘fps’]
def __init__(self, name, resolution, fps): Sensor.__init__(self, name)
But how to define the frequency of the sync loop for your sensor ?
So, existing documentation ?
EDIT : if there is no doc. I think I’ll make a simple notebook to describe how to add a sensor. Let’s read the pypot source code ![]()
