RAZOR IMU interface for Pypot
I finally wrote a class to manage the RAZOR IMU. I inherited the Razor from a Thread.
@Pierre I wanted to inherit from a Sensor class but in fact, I should instanciate a razor class inside a razorSensor class inherited from a Sensor class ? (to make it as clean as possible)
The functions are:
  • The COM port is automatically detected (I use pypot)
  • The module can get the Euler angles (in aeronautical convention)
  • but it can also return the acceleration seen by accelero, the gyro and the compass component
An example is
import razor
r = razor.Razor()
r.start()
print r.eul
print r.acc
print r.gyr
print r.mag
r.stop()
If any issue… knock me.
Here is the code :
Hi @Thot,
Nice! This will be a good extra feature!
  1. So first as a general comment, you should directly open a pull request this make commenting, improving and collaborating on code soon much easier :smile: Plus it also keeps track of the history of modification! You can open pull request as soon as you propose a new idea and not only when all the code is clean.
  2. Then, I think you should not always use auto-detection but rather make it possible for users. I’m saying that because you have to open all port and send message. Depending on what’s on the other bus this could go wrong :wink:
  3. Finally for this sensor architecture, I’ll make it clearer while I’m adding a camera sensor, qrcode detection… I’ll try to see how your Razor class can fit into that and propose you a solution. (Yours is pretty good, but defining it as a sensor will automatically make it available through the REST API and this kind of things…)
Cheers!
Ok, thanks, I am not yet friendly with git but I progress as I use it :wink:
Hello @Pierre ,
I would like to know if the Razor class created by @Thot is already available as a sensor class to be used through REST API. Thanks
Not yet. @Thot, any progress on this?
I am not yet ready.
The big issue is that the connection is not possible every 4 times… It would be useful to have the name of the ports taken by the pypot robot instanciation.
The serial port are not easy to manage with reliability…
Yep that’s a good idea! So I just add it:
You can used it like this:
from pypot.dynamixel import DxlIO
io1 = DxlIO('/dev/ttyUSB0')
io2 = DxlIO('/dev/ttyACM0')
print DxlIO.get_used_ports()
>>> ['/dev/ttyACM0', '/dev/ttyUSB0']
I also add an extra argument to the get_available_ports so you can now get only the ā€œfreeā€ ones:
from pypot.dynamixel import get_available_ports
print get_available_ports()
>>> ['/dev/ttyACM0', '/dev/ttyUSB0', '/dev/ttyUSB1']
print get_available_ports(only_free=True)
>>> ['/dev/ttyUSB1']
I’m trying to have this razor work, too.
With a timeout of 3 seconds, it works very well on my computer (ubuntu 14.04).
But on Poppy… nothing. I oppened the head and removed the USB2AX to test, still nothing.
Any idea, suggestion ?
(I’m using this file https://github.com/HumaRobotics/poppy-walk/blob/master/sensors/razor.py which is pretty much the same as Thomas linked above)
What do you say about ā€œnothingā€? Can you connect to the RAZOR ? The serial port is open ?
Or the output value is always equal to zero ?
I advise you to open the serial port in an ipython console so that you can play with it.
There is somethink to know about RAZOR, when you read a line, the first line is very long with a lot of ā€œzeroā€ characters. That is why I use the ā€œstripā€ method to remove these.
Using your code, I got ā€˜no razor connected’ each time and empty communication (or maybe only zeros as your code strips zeros right away).
But now I have a clean install and I got it to work…
Here is my code for Razor: razor.txt (5.4 KB) (it’s a python file renamed to be uploaded, with a main function so you can use it alone).
If someone (@Thot ?) could test it, I will then make a pull request to integrate it to pypot.
I tested it in Windows and in ODROID. It works very well. Very nice idea about starting by the end :wink:
This is a version that integrate get_available_ports(only_free=True) and a filter for some extraneous characters with ordinal > 127 when I read my captor
razor.py (3.4 KB)
Hello @Thot
I would like to know if there have been any advances in the question made by @JuanMiguel, are we capable of having a sensor class that could be used through the REST API?
To manage the razor sensor, we did this class but it is not yet inherited from sensor class.
